[gdal-dev] GDAL Cubic Interpolation
Harvey Berger harvey.l.berger at gmail.com
Wed Oct 11 10:06:10 PDT 2017
Thanks Joaquim and Even,
Per my email I augmented the original GLOBE image and created a properly
referenced image using gdal_translate as follows: I did an imread from
QGIS/GDAL into Octave, added the appropriate 24 rows and columns on each
side, and did an imwrite back to QGIS/GDAL to continue processing; however,
I'm having a problem with negative elevations probably due to data type
confusion.
1. GDAL reports the data type of the original GLOBE tiff file as int16.
(file = output1.tiff)
2. After using imread in Octave, Octave reports the data type as uint16.
3. I retained the uint16 data type in Octave and added the additional rows
and columns.
4. I did an imwrite to create the augmented file. (file=output2.tiff)
5. GDAL reports the data type of the augmented files as uint16.
6. I performed the following GDAL command: gdal_translate -a_ullr ulx uly
lrx lry src_dataset dst_dataset. (file=output3.tiff)
7. I then used gdalwarp to create the subsampled and cubic interpolated
file (file=sample.tiff); GDAL report the data type as int16.
The problem is with locations with negative elevations that result in
erroneous results when I subsequent subsample using gdal_warp. Here are the
elevations reported by GDAL for one example pixel in the Caspian Sea:
output1.tiff (int16): -28 m
output2.tiff (uint16): 65508 m
output3.tiff (uint16): 65508 m
Unfortunately, Octave will not perform an imwrite with a int16 data type.
Is it possible to fix this within QGIS/GDAL or is there another solution?
Thanks again for your help.
Kind regards,
Harvey
On Mon, Oct 9, 2017 at 9:32 AM, Joaquim Luis <jluis at ualg.pt> wrote:
> Alternatively,  use GMT's grdsample with -fg option to force the knowledge
> (if it's not already in the file) that the Earth is round.
> http://gmt.soest.hawaii.edu/doc/5.4.2/grdsample.html
> Harvey,
> > I subsampled a GLOBE image of elevation data by a subsampling factor of
> 12
> > to a resolution of 0.1 deg x 0.1 deg on integer multiples of 0.1 deg. The
> > original GLOBE image is: Latitude from +90-1/240 deg to -90+1/240 deg in
> > 1/120 deg steps, and Longitude from -180+1/240 deg to +180-1/240 deg in
> > 1/120 deg steps.
> > I understand that the cubic interpolation method in gdalwarp accounts for
> > the subsampling factor, so 48x48 adjacent pixels influence the target
> pixel
> > for a subsampling factor of 12.
> > Does gdalwarp assume the original image is a sphere, where 48x48 adjacent
> > pixels influence all target pixels, or a rectangle, where a limited
> number
> > of pixels influence the target pixels at the top, bottom, left, and right
> > edges of the subsampled image?
> A rectangle, with fallback to bilinear resampling at edges
> > If gdalwarp assumes the original image is a
> > rectangle and uses a modified interpolation method at the four edges of
> the
> > subsampled image, the modified method affects two rows and two columns at
> > the top, bottom, left and right edges of the subsampled image. If
> gdalwarp
> > assumes the original image is a rectangle, is there a command option so
> > gdalwarp considers spherical wrapping when interpolating?
> Nothing directly straightforward. Your below plan is the a reasonable
> solution.
> > Alternatively, I
> > assume I could augment the original GLOBE image with the appropriate
> > additional rows and columns on all four edges. If I did that, how do I
> tell
> > gdalwarp the extent of the augmented input image?
> You'll have to recreate a properly referenced input image, for example with
> gdal_translate -ullr upperleftx upperlefty lowerleftx lowerlefty
> Even
> Spatialys - Geospatial professional services
> http://www.spatialys.com
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/gdal-dev
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20171011/25de3735/attachment.html>
