[gdal-dev] WCS driver
Ari Jolma ari.jolma at gmail.com
Tue Oct 24 07:07:51 PDT 2017
Whoa! How hard can XML be? I have a real Capabilities document (from
well known company) which defines *both* default and ows namespace to
http://www.opengis.net/ows/2.0.
Thus, to be sure, I need to look for *both* ows:ServiceIdentification
and ServiceIdentification. Or maybe loop through all elements and check
for both at each element?
And additional spice is that in WCS 1.1.0 ServiceIdentification is in
namespace http://www.opengis.net/wcs/1.1/ows. :)
Ari
Even Rouault kirjoitti 24.10.2017 klo 12:45:
> > Is there any reason not to switch to libxml2 from minixml?
> > I see only GMLAS driver uses libxml2 currently
> Ah, yes indirectly when it validates the data/gmlasconf.xml file
> against data/gmlasconf.xsd, since CPLValidateXML() uses libxml2
> underneath to do that (it could actually have an alternate
> implementation using Xerces-C validation functionnalities.)
> > , and maybe OGR VRT.
> Same thing, OGR VRT, optionnaly, uses libxml2 to validate the .vrt
> file against its schema.
> But minixml functionnality should be enough for WCS purposes, and
> libxml2 and Xerces-C remain optional dependencies.
> Even
> Spatialys - Geospatial professional services
> http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20171024/583cdf40/attachment.html>
