[gdal-dev] Opening gridded xyz data that is out of order
Andreas Neumann a.neumann at carto.net
Mon Sep 11 06:51:26 PDT 2017
Forgot to mention the link to the file, just in case you have time
testing - see https://services.geo.zg.ch/temp/dtmav.zip (138 MB zipped
file).
Thanks,
Andreas
On 11.09.2017 15:43, Andreas Neumann wrote:
> Hi,
> I received a DTM from a Swiss province (OpenData) which is of the
> following format:
> One coordinate per line, already gridded. See f.e.
> 2708001.00 1218001.00 1541.52
> 2708003.00 1218001.00 1542.35
> 2708005.00 1218001.00 1542.98
> 2708007.00 1218001.00 1543.58
> 2708009.00 1218001.00 1544.20
> 2708011.00 1218001.00 1545.13
> 2708013.00 1218001.00 1545.88
> The issue is that further down the file there seems to be an issue of
> ordering the coordinates. gdalinfo produces the following error:
> ERROR 1: Ungridded dataset: At line 4125001, change of Y direction
> gdalinfo failed - unable to open 'DTM_swissALTI3D_XYZ.txt'.
> If GDAL could open the data - it would open as ungridded data - right?
> Issue is, this data is already gridded as you can see above. I
> actually want to save this is a gridded GeoTIFF file for later usage
> in QGIS.
> Is there still a chance that GDAL can open this data set, even if
> coordinates are out of order?
> How about the gridded vs ungridded aspect of xyz files?
> Thanks,
> Andreas
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/gdal-dev
