[gdal-dev] Opening gridded xyz data that is out of order
Andreas Neumann a.neumann at carto.net
Mon Sep 11 07:52:07 PDT 2017
Yes - I am aware of gdal_translate and gdalwarp to translate formats.
Thanks a lot. I am very happy that this was so easy to solve and now I
can use this data in QGIS.
I think the data provider just concatenated chunks of existing files and
did not care about the order. I will ask them to run the magic sort
command you provided before delivering the data to their clients.
Thanks,
Andreas
On 11.09.2017 16:44, Mark Johnson wrote:
> This will do the same, just replace the EPSG code number:
> gdal_translate -ot Float32 -a_srs EPSG:25833
> ../xyz/390_5820.dhhn92.txt ../2007.390_5820.dhhn92.25833.tif
> Mark
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/gdal-dev
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20170911/461e4b7c/attachment.html>
