[gdal-dev] Opening gridded xyz data that is out of order
Richard Barnes rbarnes at umn.edu
Mon Sep 11 09:17:31 PDT 2017
I wonder if GDAL shouldn't suggest sorting as a means of fixing the issue,
possibly with Mark's command?
On Sep 11, 2017 7:32 AM, "Andreas Neumann" <a.neumann at carto.net> wrote:
> Hi Mark (and others),
> Your sort command worked like a charm. It was also very fast!
> Now gdalinfo produces this nice information output:
> Driver: XYZ/ASCII Gridded XYZ
> Files: dtmav_sorted.xyz
> Size is 5000, 5000
> Coordinate System is `'
> Origin = (2708000.000000000000000,1210000.000000000000000)
> Pixel Size = (2.000000000000000,2.000000000000000)
> Corner Coordinates:
> Upper Left  ( 2708000.000, 1210000.000)
> Lower Left  ( 2708000.000, 1220000.000)
> Upper Right ( 2718000.000, 1210000.000)
> Lower Right ( 2718000.000, 1220000.000)
> Center      ( 2713000.000, 1215000.000)
> Band 1 Block=5000x1 Type=Float32, ColorInterp=Undefined
>   Min=728.210 Max=2294.290
>   NoData Value=0
> Now I can open this in QGIS as a normal data source and simply safe as a
> GeoTIFF file.
> Thanks a lot to all who answered so quickly!
> Glad that a simple sort command on the command line helped to solve the
> issue! I will contact the data provider and ask them if they could deliver
> this data in an already sorted form so that GDAL recognizes it as gridded
> data.
> Andreas
> On 11.09.2017 16:12, Mark Johnson wrote:
> You must sort the data beforehand
> - the y position must be sorted properly (ASC or DESC)
> Standard linux sort program:
> sort -k2 -n -k1 392_5810.xyz -o 392_5810.sort.xyz
> (2nd column (y) as numeric, then first column (x) -o = output file
> As a zip file you can also do:
> unzip -p 390_5820.zip | sort -k2 -n -k1 -o ../xyz/390_5820.dhhn92.txt
> that would deal with problem in 1 step.
> ogr needs to know the range/area to build (minx,miny,maxx, maxy), so when
> the y switches it assumes a new column.
> Mark
> gdal-dev mailing listgdal-dev at lists.osgeo.orghttps://lists.osgeo.org/mailman/listinfo/gdal-dev
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20170911/b31a2ebd/attachment.html>
