[gdal-dev] illegal axis orientation combination when re-projecting
Nick Cummins nickmcummins at icloud.com
Tue Sep 12 16:06:28 PDT 2017
TOWNSSURVEY_POLY.shp in
http://wsgw.mass.gov/data/gispub/shape/state/townssurvey_shp.zip
ogr2ogr -f "GeoJSON" -t_srs EPSG:4326 dest.json TOWNSSURVEY_POLY.shp
produces the error for me
On Sep 12, 2017, at 04:01 PM, Even Rouault <even.rouault at spatialys.com> wrote:
On mardi 12 septembre 2017 21:55:31 CEST Nick Cummins wrote:
> I'm trying to re-project a lidar point cloud file using PDAL, which uses
> GDAL under the hood. When re-projecting a .las tile which I was previously
> able to successfully transform the coordinate system from EPSG:4269
> (lat/lon) to a US state plane projection, EPSG:102749, I now get the
> following error:
> (pdal pipeline filters.reprojection Error) GDAL failure (1) illegal axis
> orientation combination (pdal pipeline filters.reprojection Error) GDAL
> failure (1) Reprojection failed, err = -47, further errors will be
> suppressed on the transform object. *** Error in `pdal': munmap_chunk():
> invalid pointer: 0x00007f4ab1fec400 ***
> I was looking online and found someone with a similar issue when running
> ogr2ogr to re-project a shapefile. I am able to reproduce an error running
> the command and data described:
Nick,
Can you point to a link to the source shapefile that triggers the crash ?
Even
http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20170912/6c2d18b9/attachment.html>
