[gdal-dev] illegal axis orientation combination when re-projecting
Nick Cummins nickmcummins at icloud.com
Wed Sep 13 09:58:14 PDT 2017
➜ ls -lah /usr/lib/ | grep -i libproj
lrwxrwxrwx   1 root root    17 Sep 14  2016 libproj.so -> libproj.so.12.0.0
lrwxrwxrwx   1 root root    17 Sep 14  2016 libproj.so.12 -> libproj.so.12.0.0
-rwxr-xr-x   1 root root  423K Sep 14  2016 libproj.so.12.0.0
Also,
➜ ldd /usr/bin/ogr2ogr | grep -i proj
libproj.so.12 => /usr/lib/libproj.so.12 (0x00007fcbcfd92000)
➜ /usr/bin/ogr2ogr | grep -i spatial
libspatialite.so.7 => /usr/lib/libspatialite.so.7 (0x00007f20274ad000)
➜ ldd /usr/lib/libspatialite.so.7 | grep -i proj
libproj.so.12 => /usr/lib/libproj.so.12 (0x00007f7c7a032000)
➜ print $LD_LIBRARY_PATH
/usr/lib:/usr/lib32
On Sep 13, 2017, at 02:22 AM, Even Rouault <even.rouault at spatialys.com> wrote:
On mardi 12 septembre 2017 23:47:09 CEST Nick Cummins wrote:
> I am using Arch Linux (continuous/rolling distro), using gdal from the
> official repositories.
> Using proj. 4.9.3-1 from official repos.
> As mentioned, previously (within the past month) the first re-projection
> example was working fine. Suddenly today I was analyzing a different tile
> and ran into the error, and I have not made any changes to my setup that I
> am aware of that would change behavior.
> Output of running ogr2ogr with valgrind in attached file.
It crashes in proj.4. But the lines mentionned are weird : pj_free (pj_init.c:496). At line 496 of pj_init.c, this is not the pj_free() function. Perhaps due to optimizations that mess up line reporting. I tried with proj 4.9.3 and it works fine for me.
I see from
https://git.archlinux.org/svntogit/community.git/tree/trunk/PKGBUILD?h=packages/gdal that archlinux doesn't build with GDAL with --with-static-proj4, so I'm wondering if there isn't a mix of proj.4 versions. Isn't there a chance that one of the dependencies of GDAL links against a libproj.so.X (spatialite could be a good candidate) and that GDAL then loads a libproj.so that is a symlink to libproj.so.Y
Can you check your /usr/lib/libproj.so* files ?
Even
http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20170913/afffa83c/attachment.html>
