[gdal-dev] Gdal2tiles gains parallel processing features
Even Rouault even.rouault at spatialys.com
Fri Sep 29 08:59:10 PDT 2017
On vendredi 29 septembre 2017 17:50:11 CEST Grégory Bataille wrote:
> Hi all,
> I just wanted to announce that after a few months of work (took long, I got
> lazy), *gdal2tiles has gained parallel computing abilities*
> It is now *on trunk*.
Thanks for your great work on this
> - Because the rewrite + the pararellization are a big and risky work (since
> there were no tests really), there is a new gdal2tiles_old.py script on
> trunk to provide an easy "back-out" for people who would get into trouble
> in their production
Note: I actually removed gdal2tiles_old.py when merging your work back into SVN (should
have told you before). It was the same as the version you can find in the 2.2 branch, so one
could still grab it from there if really needed.
Even
http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20170929/4b170ed5/attachment.html>
