[gdal-dev] Gdal2tiles gains parallel processing features
Grégory Bataille gregory.bataille at gmail.com
Fri Sep 29 09:05:26 PDT 2017
oh... ok for gdal2tiles_old.py.
I just wished to make a potential rollback "easy"
Anyway, that's good enough for me :)
Thanks
Gregory Bataille
On Fri, Sep 29, 2017 at 5:59 PM, Even Rouault <even.rouault at spatialys.com>
wrote:
> On vendredi 29 septembre 2017 17:50:11 CEST Grégory Bataille wrote:
> > Hi all,
> > I just wanted to announce that after a few months of work (took long, I
> got
> > lazy), *gdal2tiles has gained parallel computing abilities*
> > It is now *on trunk*.
> Thanks for your great work on this
> > - Because the rewrite + the pararellization are a big and risky work
> (since
> > there were no tests really), there is a new gdal2tiles_old.py script on
> > trunk to provide an easy "back-out" for people who would get into trouble
> > in their production
> Note: I actually removed gdal2tiles_old.py when merging your work back
> into SVN (should have told you before). It was the same as the version you
> can find in the 2.2 branch, so one could still grab it from there if really
> needed.
> Even
> Spatialys - Geospatial professional services
> http://www.spatialys.com
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/gdal-dev
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20170929/bbfa9218/attachment.html>
