[gdal-dev] Understanding VSI caching
Andrea Aime andrea.aime at geo-solutions.it
Mon Apr 9 11:51:43 PDT 2018
On Mon, Apr 9, 2018 at 6:43 PM, Even Rouault <even.rouault at spatialys.com>
wrote:
> Hi Andrea,
> Are you speaking about the cache machanism enabled with the VSI_CACHE=YES
> env variable ?
I read there was some caching, but was not that specific. So, memory
caching is there, it's per file,
but not enabled by default, while disk caching is there, global, and
enabled by default?
> If so that's described at
> http://gdal.org/gdal_virtual_file_systems.html#gdal_
> virtual_file_systems_vsicache
> I see it lacks a bit high level details, like specifying this is RAM only,
> and not disk cached.
> I'm going to add some words about that
> Otherwise, the full "documentation" :-) is at:
> https://github.com/OSGeo/gdal/blob/master/gdal/port/cpl_vsil_cache.cpp
Hehehe :-)
> The /vsicurl/ and related network file systems have also their own RAM
> cache mechanism
> described at
> virtual_file_systems_vsicurl
The "detect sequential reading" part is interesting, if I'm not mistaken
the logic is here,
right?
https://github.com/OSGeo/gdal/blob/master/gdal/port/cpl_vsil_curl.cpp#L1845
Thanks a lot for the useful information, as usual :-)
Cheers
Andrea
GeoServer Professional Services from the experts! Visit http://goo.gl/it488V
for more information.
Ing. Andrea Aime
@geowolf
Technical Lead
GeoSolutions S.A.S.
Via di Montramito 3/A
55054  Massarosa (LU)
phone: +39 0584 962313
fax: +39 0584 1660272
mob: +39  339 8844549
http://www.geo-solutions.it
nel/i file/s allegato/i sono da considerarsi strettamente riservate. Il
loro utilizzo è consentito esclusivamente al destinatario del messaggio,
per le finalità indicate nel messaggio stesso. Qualora riceviate questo
messaggio senza esserne il destinatario, Vi preghiamo cortesemente di
darcene notizia via e-mail e di procedere alla distruzione del messaggio
stesso, cancellandolo dal Vostro sistema. Conservare il messaggio stesso,
divulgarlo anche in parte, distribuirlo ad altri soggetti, copiarlo, od
utilizzarlo per finalità diverse, costituisce comportamento contrario ai
information in this message that has been received in error. The sender
does not give any warranty or accept liability as the content, accuracy or
completeness of sent messages and accepts no responsibility  for changes
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20180409/3f53ccbf/attachment.html>
