[gdal-dev] Warping EUMetsat MSG-4 MPE dataset to webmercator projection
Menno van Scheers - HUSS menno at huss.nl
Thu Apr 19 02:17:35 PDT 2018
Built version 2.2.4 of gdal with no additional libraries.
Currently trying to warp a grib dataset to webmercator projection with the following arguments :
gdalwarp  -t_srs "+proj=geos +lon_0=0 +h=35785831 +x_0=0 +y_0=0 +a=6378140 +b=6356755 +units=m +no_defs"  201804181115_L-000-MSG4__-MPEF________-MPEG_____-000000___-201804181115-__.grib webm.tiff
This task fails with : ERROR 1: Too many points (5625 out of 5625) failed to transform, unable to compute output bounds.
Source dataset has a geostationary projection
Basic info on the dataset :
PROJ.4 string is:
'+proj=geos +lon_0=0 +h=35785831 +x_0=0 +y_0=0 +a=6378140 +b=6356755 +units=m +no_defs '
Origin = (-5570248.477582973428071,5570248.477582973428071)
Pixel Size = (3000.403165948275728,-3000.403165948275728)
Corner Coordinates:
Upper Left  (-5570248.478, 5570248.478) ERROR 1: tolerance condition error
Lower Left  (-5570248.478,-5567248.074) ERROR 1: tolerance condition error
Upper Right ( 5567248.074, 5570248.478) ERROR 1: tolerance condition error
Lower Right ( 5567248.074,-5567248.074) ERROR 1: tolerance condition error
Example of the dataset :
https://hussbv-my.sharepoint.com/:u:/g/personal/menno_huss_nl/EQwTxBKwPQlOjPZ_DZcuZWcBgBs0y96_9Vev3tIqnne3KA?e=k6hmYU
Any help would be appreciated.
Menno van Scheers
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20180419/2383944d/attachment.html>
