[gdal-dev] Can't set clipsrc for gdal_grid utility
    Nikolai Bezdna
    mofoyoda at gmail.com
    Fri Dec  7 02:28:48 PST 2018
I’m getting strange errors when using gdal_grid with clipsrc parameter:
When setting options like this:
-clipsrc "PG:dbname='postgres' host='dev.urbica.co' port='35488' user='postgres' password='postgres'" \
-clipsrcsql 'SELECT id, geom AS geometry FROM osm.city_boundary AS o'
I get
ERROR 1: Unable to open secondary datasource `osm' required by JOIN.
ERROR 1: Failed to identify source layer from datasource.
ERROR 1: Cannot load source clip geometry.
When trying to use a shapefile or geojson instead of DB table like this:
-clipsrc bnd.shp
OR
-clipsrc bnd.geojson
I get
ERROR 4: `bnd.shp' not recognized as a supported file format.
I've checked my files with ogrinfo and QGIS - they're valid and contain one feature with multipolygon geometry:
INFO: Open of `bnd.geojson'
      using driver `GeoJSON' successful.
1: bnd (Multi Polygon)
How do I set clipping for gdal_grid output?
