[gdal-dev] ogrInfo error - Entry Point Not Found
Andre Joost andre+joost at nurfuerspam.de
Mon Jan 29 01:05:19 PST 2018
Am 29.01.18 um 01:04 schrieb john polo:
> Hi,
> I am attempting to use ogrInfo to get information about a geodatabase. I
> am using Windows 7 64bit. I have GDAL  installed with QGIS. The QGIS is
> 2.18.3, but I can't find how to tell the version of GDAL that's
> installed. I don't know much about working with a lot of the OSGeo4W64
> software, especially when it comes to software libraries, please bear
> with me if I do not provide the necessary information.
> I looked up how to read the geodatabase with PostgreSQL. It seems I need
> to first use ogrInfo to read what's in the geodatabase and then maybe
> get PostGIS involved. This will probably lead to another question on
> another list. :) Anyway, on the Windows command prompt, I used
> ogrInfo C:\directories\geodatabase.gdb
> and I get this error:
> "ogrinfo.exe - Entry Point Not Found
> The procedure entry point SSL_COMP_free_compression_methods could not be
> located in the dynamic link library SSLEAY32.dll
Most probably you have an outdated version of SSLEAY32.dll, or different
versions in different places.
HTH,
Andre Joost
