[gdal-dev] About deprecated CRS and the different behavior of EPSGGetPCSInfo and EPSGGetGCSInfo
andreaerdna andreaerdna at libero.it
Tue May 15 05:01:19 PDT 2018
Even Rouault-2 wrote
> Implemented per https://github.com/OSGeo/gdal/pull/575
Thanks, Even!
Taking a better look at importFromEPSG and how it's used by QGIS
QgsCoordinateReferenceSystem::syncDb(), I think that it will be useful to
uniform also the names of deprecated **GEOCCS** (Geocentric Coordinate
Systems) implementing your fix in **SetEPSGGeocCS** ('cause there's no
"EPSGGetGCCSInfo") too.
Just for completeness, the behavior of SetEPSGCompdCS and SetEPSGVertCS
(that are also used by importFromEPSG) about deprecated CS does not affect
QgsCoordinateReferenceSystem::syncDb(): in fact for compound coordinate
system (COMPD_CS), syncDB always use the related horizontal projcs or geogcs
name, while for vertical coordinate system it does not care of the name.
Best regards and good work.
Andrea Giudiceandrea
Sent from: http://osgeo-org.1560.x6.nabble.com/GDAL-Dev-f3742093.html
