[gdal-dev] Alternative to GPKG format
koji higuchi koji51guchi at gmail.com
Thu Nov 1 03:16:00 PDT 2018
Hi Jukka
Is osmium-extract available in pyosmium?
i'm using windows; and seems difficult to use osmium in windows
On Thu, Nov 1, 2018 at 7:13 PM jratike80 <
jukka.rahkonen at maanmittauslaitos.fi> wrote:
> Hi,
> That is probably another problem, OSM pbf format does not support effective
> selection by region so selecting a subarea from europe-latest.osm.pbf may
> be
> almost as slow as processing the whole dataset. I would try if
> osmium-extract https://docs.osmcode.org/osmium/latest/osmium-extract.html
> could do the clipping  faster.
> -Jukka Rahkonen-
> koji higuchi wrote
> > Hi, my source file is too big, around 19gb (europe-latest.osm.pbf)
> > I also tried ogr2ogr for clipping into region as follows.
> > ogr2ogr -f,  gpkg,  -clipdst, str(ulx), str(lry), str(lrx), str(uly), fo,
> > fi
> > but it was also very slow.
> > On Thu, Nov 1, 2018 at 6:55 PM jratike80 <
> > jukka.rahkonen@
> >> wrote:
> >> koji higuchi wrote
> >> > Hi, following is the code I used:
> >> > Import os, osmium, fiona
> >> > fi = 'europe-latest.osm.pbf'
> >> > fo = 'europe-latest.dpkg'
> >> > drv = 'DPKG'
> >> Hi,
> >> I am not able to evaluate if your code is effective or not. However, I
> >> can
> >> give you some numbers for comparison.
> >> Test data http://download.geofabrik.de/europe/finland-latest.osm.pbf
> >> - 322 MB as .pbf
> >> - 770725 points
> >> - 1778917 lines
> >> - 3128 multilinestrings
> >> - 2087911 multipolygons
> >> - 6985 other relations
> >> Command:
> >> ogr2ogr -f gpkg finland.gpkg finland-latest.osm.pbf
> >> Execution time on Windows laptop:
> >> 2 minutes and 20 seconds
> >> If you experience some slower performance it is probably not because of
> >> SQLite/GeoPackage as a format is slow but because something is not done
> >> in
> >> a
> >> way that is not optimal for the format. Could you also define your
> source
> >> data and the performance that you have measured?
> >> -Jukka Rahkonen-
> Sent from: http://osgeo-org.1560.x6.nabble.com/GDAL-Dev-f3742093.html
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/gdal-dev
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20181101/c8c7b9b1/attachment.html>
