[gdal-dev] Alternative to GPKG format
jratike80 jukka.rahkonen at maanmittauslaitos.fi
Thu Nov 1 03:38:37 PDT 2018
Unfortunately I have never used osmium-extract myself but I was remembering
that I had been reading something about doing spatial selection from OSM
pbf. I did even find the thread
https://lists.openstreetmap.org/pipermail/dev/2018-October/030400.html
-Jukka-
koji higuchi wrote
> Hi Jukka
> Is osmium-extract available in pyosmium?
> i'm using windows; and seems difficult to use osmium in windows
> On Thu, Nov 1, 2018 at 7:13 PM jratike80 <
> jukka.rahkonen@
>> wrote:
>> Hi,
>> That is probably another problem, OSM pbf format does not support
>> effective
>> selection by region so selecting a subarea from europe-latest.osm.pbf may
>> be
>> almost as slow as processing the whole dataset. I would try if
>> osmium-extract https://docs.osmcode.org/osmium/latest/osmium-extract.html
>> could do the clipping  faster.
>> -Jukka Rahkonen-
>> koji higuchi wrote
>> > Hi, my source file is too big, around 19gb (europe-latest.osm.pbf)
>> > I also tried ogr2ogr for clipping into region as follows.
>> > ogr2ogr -f,  gpkg,  -clipdst, str(ulx), str(lry), str(lrx), str(uly),
>> fo,
>> > fi
>> > but it was also very slow.
>> > On Thu, Nov 1, 2018 at 6:55 PM jratike80 <
>> > jukka.rahkonen@
>> >> wrote:
>> >> koji higuchi wrote
>> >> > Hi, following is the code I used:
>> >> > Import os, osmium, fiona
>> >> > fi = 'europe-latest.osm.pbf'
>> >> > fo = 'europe-latest.dpkg'
>> >> > drv = 'DPKG'
>> >> Hi,
>> >> I am not able to evaluate if your code is effective or not. However, I
>> >> can
>> >> give you some numbers for comparison.
>> >> Test data http://download.geofabrik.de/europe/finland-latest.osm.pbf
>> >> - 322 MB as .pbf
>> >> - 770725 points
>> >> - 1778917 lines
>> >> - 3128 multilinestrings
>> >> - 2087911 multipolygons
>> >> - 6985 other relations
>> >> Command:
>> >> ogr2ogr -f gpkg finland.gpkg finland-latest.osm.pbf
>> >> Execution time on Windows laptop:
>> >> 2 minutes and 20 seconds
>> >> If you experience some slower performance it is probably not because
>> of
>> >> SQLite/GeoPackage as a format is slow but because something is not
>> done
>> >> in
>> >> a
>> >> way that is not optimal for the format. Could you also define your
>> source
>> >> data and the performance that you have measured?
>> >> -Jukka Rahkonen-
>> Sent from: http://osgeo-org.1560.x6.nabble.com/GDAL-Dev-f3742093.html
>> gdal-dev mailing list
> gdal-dev at .osgeo
>> https://lists.osgeo.org/mailman/listinfo/gdal-dev
> gdal-dev at .osgeo
