[gdal-dev] ESRI FileGDB driver causing issues with Postgis build due to packaged libstdc++
Even Rouault even.rouault at spatialys.com
Thu Sep 26 15:04:01 PDT 2019
> /usr/bin/clang-7: /usr/local/FileGDB_API/lib/libstdc++.so.6: version
> `GLIBCXX_3.4.22' not found (required by
Try removing that /usr/local/FileGDB_API/lib/libstdc++.so.6 . It is likely
older than what the rest of your system expects.
http://www.spatialys.com
