[gdal-dev] Help with CPL_DEBUG
Joaquim Manuel Freire Luís jluis at ualg.pt
Mon Feb 17 09:34:15 PST 2020
On Mon, 17 Feb 2020 at 18:05, Joaquim Manuel Freire Luís <jluis at ualg.pt> wrote:
>> Hi Even,
> FYI, you have e-mailed the public gdal-dev mailing list.
Yes, I know but since Even responds all the times ... I took the liberty
I also read that page, and used "CPL_DEBUG=ON" in my command, but no message was printed hence my suspicion that I might not be using it correctly.
> I have no idea why that might happen and tried to run it with
> CPL_DEBUG as in gmt grdgdal lixo.csv -R0/10/0/10 -Gjunk.nc -I0.05 -F"-a nearest -co CPL_DEBUG=ON"
> (this is a mixed GMT and GDAL syntax (the part under double quotes),
> never mind. It just works locally)
> But got no debug printouts from the CI test. Am I wrongly using the
> CPL_DEBUG? All GDAL versions in CI are above 2.1
See https://trac.osgeo.org/gdal/wiki/ConfigOptions#CPL_DEBUG, may help.
Best regards,
Mateusz Loskot, http://mateusz.loskot.net _______________________________________________
gdal-dev at lists.osgeo.org
https://lists.osgeo.org/mailman/listinfo/gdal-dev
