[gdal-dev] Help with CPL_DEBUG
Mateusz Loskot mateusz at loskot.net
Mon Feb 17 09:28:45 PST 2020
On Mon, 17 Feb 2020 at 18:05, Joaquim Manuel Freire Luís <jluis at ualg.pt> wrote:
> Hi Even,
FYI, you have e-mailed the public gdal-dev mailing list.
> I have no idea why that might happen and tried to run it with CPL_DEBUG as in
> gmt grdgdal lixo.csv -R0/10/0/10 -Gjunk.nc -I0.05 -F"-a nearest -co CPL_DEBUG=ON"
> (this is a mixed GMT and GDAL syntax (the part under double quotes), never mind. It just works locally)
> But got no debug printouts from the CI test. Am I wrongly using the CPL_DEBUG? All GDAL versions in CI are above 2.1
See https://trac.osgeo.org/gdal/wiki/ConfigOptions#CPL_DEBUG, may help.
Best regards,
Mateusz Loskot, http://mateusz.loskot.net
