[gdal-dev] Experiments with the gdal_grid C API
Joaquim Manuel Freire Luís jluis at ualg.pt
Tue Jan 28 06:05:52 PST 2020
>> Should be -of MEM. That's tested in autotest/utilities/test_gdal_grid_lib.py
> An alternative is to use a /vsimem/temp.tif with the GTiff driver (but you need to VSIUnlink() > the file once done to avoid mem leaks). But the MEM driver should do it.
Cool, with -of MEM and still using "NUL" I was able to create a ~480 Mb compressed nc file so I interpret this as:
"It worked and it didn't get the grid from GDAL block cache"
> The gdal grid API doesn't support updating an existing dataset. If it had, then you could have > created a MEM dataset based on your own array.
That was one of my first thoughts but could find a way to send in MEM dataset. Maybe some day?
Thanks, I have something usable now.
Joaquim
