[gdal-dev] Transform produces different results from 2.2.4 and 3.0.2 or 3.0.3
mike Null gdisk.mike at gmail.com
Tue Jan 28 07:54:30 PST 2020
So, I'm finding a difference between results....
def epsg_test():
    import ogr
    import osr
    wgs84_osr = osr.SpatialReference()
    wgs84_osr.ImportFromEPSG(4326)
    utm17_osr = osr.SpatialReference()
    utm17_osr.ImportFromEPSG(32617)
    transform = osr.CoordinateTransformation(wgs84_osr, utm17_osr)
    inputwkt = 'Point (-81.5 30.5)'
    ingeom = ogr.CreateGeometryFromWkt(inputwkt,wgs84_osr)
    print(ingeom.ExportToWkt())
    ingeom.Transform(transform)
gdal 3.0.3, proj 6.3.0, with python 3.7 (also seen on 3.0.2, proj 6.2.1)
POINT (-81.5 30.5)
POINT (1385293.10269892 -10347979.9101242)
gdal 2.2.4, proj 4.9.3, with python 2.7
POINT (-81.5 30.5)
POINT (452019.438629914 3374297.77348828)
Gdal/proj was installed via qgis standalone installer.
I do believe the python2/gdal2 result is correct, or at least it agreed
with the project tool on esri and epsg.io.
epsg.io/transform#s_srs=4326&t_srs=32617&x=-81.5&y=30.5
Anyways I desire to use python 3 and gdal 3.
What might I need to do to get it working correctly? I know there was a lot
of changes with gdalbarn/proj.
-Mike
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20200128/c00a0c34/attachment.html>
