[gdal-dev] new NBM grib2 files are not warpable
Thomas Horner haevitetty at gmail.com
Fri Jun 5 10:42:39 PDT 2020
Hello list,
The US National Weather Service recently released version 3.2 of their NBM
weather model blend. I have not been able to successfully to use gdalwarp
or gdal_translate on these GRIB2 files. For gdal_translate, I get an
"Error: Out of memory" error, even though it's only 80mb and I have 16gb of
RAM.
This is what happens when using gdalwarp to warp to EPSG:4326:
> thomas at eolus:~/model_processing/tempWxData$ gdalwarp
nbm_20200605_16Z_t001.grib2 nbm.tif -t_srs EPSG:4326 -multi
Processing nbm_20200605_16Z_t001.grib2 [1/1] : 0Using internal nodata
values (e.g. 9999) for image nbm_20200605_16Z_t001.grib2.
ERROR 1: Too many points (529 out of 529) failed to transform, unable to
compute output bounds.
Warning 1: Unable to compute source region for output window 0,0,2345,1597,
skipping.
gdalinfo reveals the following information about the CRS:
Driver: GRIB/GRIdded Binary (.grb, .grb2)
Files: nbm_20200605_16Z_t001.grib2
Size is 2345, 1597
Coordinate System is:
PROJCRS["unnamed",
    BASEGEOGCRS["Coordinate System imported from GRIB file",
        DATUM["unnamed",
            ELLIPSOID["Sphere",6371200,0,
                LENGTHUNIT["metre",1,
                    ID["EPSG",9001]]]],
        PRIMEM["Greenwich",0,
            ANGLEUNIT["degree",0.0174532925199433,
                ID["EPSG",9122]]]],
    CONVERSION["unnamed",
        METHOD["Lambert Conic Conformal (2SP)",
            ID["EPSG",9802]],
        PARAMETER["Latitude of false origin",25,
            ANGLEUNIT["degree",0.0174532925199433],
            ID["EPSG",8821]],
        PARAMETER["Longitude of false origin",265,
            ID["EPSG",8822]],
        PARAMETER["Latitude of 1st standard parallel",25,
            ID["EPSG",8823]],
        PARAMETER["Latitude of 2nd standard parallel",25,
            ID["EPSG",8824]],
        PARAMETER["Easting at false origin",0,
            LENGTHUNIT["Metre",1],
            ID["EPSG",8826]],
        PARAMETER["Northing at false origin",0,
            ID["EPSG",8827]]],
    CS[Cartesian,2],
        AXIS["easting",east,
            ORDER[1],
            LENGTHUNIT["Metre",1]],
        AXIS["northing",north,
            ORDER[2],
            LENGTHUNIT["Metre",1]]]
Data axis to CRS axis mapping: 1,2
Origin = (-3272421.457337170839310,3790842.106035435572267)
Pixel Size = (2539.702999999999975,-2539.702999999999975)
Corner Coordinates:
Upper Left  (-3272421.457, 3790842.106) (138d23'39.07"W, 53d 3'24.76"N)
Lower Left  (-3272421.457, -265063.585) (126d17' 8.03"W, 19d12'55.22"N)
Upper Right ( 2683182.078, 3790842.106) ( 59d 1'17.54"W, 54d22'46.84"N)
Lower Right ( 2683182.078, -265063.585) ( 69d11'54.98"W, 20d19' 6.30"N)
Center      ( -294619.690, 1762889.261) ( 98d21'20.81"W, 40d37' 0.08"N)
If you want a file to test with, download from here:
https://nomads.ncep.noaa.gov/pub/data/nccf/com/blend/prod/blend.20200605/16/grib2/blend.t16z.master.f001.co.grib2
That file will be removed after a couple days though.
I don't know the details of coordinate transformation, so I have no idea
how to solve this problem. Can anyone help?
Thanks,
Thomas
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20200605/97641560/attachment.html>
