[gdal-dev] Documentation for previous versions
Howard Butler howard at hobu.co
Mon Jun 8 11:53:44 PDT 2020
Jon,
The way to get point-in-time docs for GDAL is to check out the last release branch for the version you care about and run doxygen or sphinx (3.0+) to build the HTML site.
Other than that, Sphinx does support multi-version tagging, but it would be a lot of work to retroactively apply tagging to the docs. A patch that did so would be welcomed.
Howard
> On Jun 5, 2020, at 2:48 AM, Jon Morris <Jon.Morris at jbarisk.com> wrote:
> Hi Thomas,
> Looks like that is my best bet. Python docs are on there, so Wayback Machine saves the day again!
> Thanks,
> Jon
> From: Thomas Juntunen <junt0015 at umn.edu <mailto:junt0015 at umn.edu>>
> Sent: 04 June 2020 15:12
> To: Jon Morris <Jon.Morris at jbarisk.com <mailto:Jon.Morris at jbarisk.com>>
> Cc: gdal-dev at lists.osgeo.org <mailto:gdal-dev at lists.osgeo.org>
> Subject: Re: [gdal-dev] Documentation for previous versions
> Hi Jon,
> Maybe the Wayback Machine can help? For example, this url gets you the GDAL site from 2018 when 2.3 was new:
> https://web.archive.org/web/20180723211153/http://gdal.org/index.html <https://web.archive.org/web/20180723211153/http:/gdal.org/index.html>
> Thomas
> On Thu, Jun 4, 2020 at 3:00 AM Jon Morris <Jon.Morris at jbarisk.com <mailto:Jon.Morris at jbarisk.com>> wrote:
> Hello all,
> I was wondering where we could find documentation for previous versions of GDAL? We are still using version 2.2.0 and there are occasions when we see a useful method in the docs only to find it is not available in our version. I presume the docs available at https://gdal.org/api/index.html <https://gdal.org/api/index.html> are for the latest released version?
> I managed to install Doxygen and build docs for us to view locally, so we do actually have a C API reference for version 2.2.0 now, but I can't find where the Python docs are in the source. It would also be very useful to be able to see a different version of the docs at https://gdal.org/python/index.html <https://gdal.org/python/index.html>.
> Thanks,
> Jon
> Jon Morris
> Software Developer
> Skype
> COVID-19. During the current outbreak JBA remains open for business and we continue to deliver our services. However, we have adopted flexible/remote workingas required. I will be receiving and reading email as normal but I may not always be available on the office number.
>  <https://www.jbagroup.co.uk/sites/www.jbagroup.co.uk/files/documents/15-030%20JBA%20Business%20Continuity%20Briefing%20-%20Latest.pdf>
> T +44 (0) 1756 799919
> www.jbarisk.com <http://www.jbarisk.com/>
>  <http://www.jbarisk.com/>  <https://www.linkedin.com/in/jon-morris-a2897b4/>  <https://twitter.com/jbarisk>
> Our postal address and registered office is JBA Risk Management Limited, 1 Broughton Park, Old Lane North, Broughton, Skipton, North Yorkshire BD23 3FD.
> Find out more about us here: www.jbarisk.com <http://www.jbarisk.com/> and follow us on Twitter @JBARisk <http://twitter.com/JBARisk> and LinkedIn <https://www.linkedin.com/company/2370847?trk=tyah&trkInfo=clickedVertical%3Acompany%2CclickedEntityId%3A2370847%2Cidx%3A2-1-2%2CtarId%3A1447414259786%2Ctas%3AJBA%20RISK%20MANAGEMENT>
> The JBA Group supports the JBA Trust.
> All JBA Risk Management's email messages contain confidential information and are intended only for the individual(s) named. If you are not the named addressee you should not disseminate, distribute or copy this e-mail.
> Please notify the sender immediately by email if you have received this email by mistake and delete this email from your system.
> JBA Risk Management Limited is registered in England, company number 07732946, 1 Broughton Park, Old Lane North, Broughton, Skipton, North Yorkshire, BD23 3FD, Telephone: +441756799919
> gdal-dev mailing list
> https://lists.osgeo.org/mailman/listinfo/gdal-dev <https://lists.osgeo.org/mailman/listinfo/gdal-dev>
> The right coordinate system can turn an impossible problem into two really hard problems. -- Charlie Pellerin
> Thomas Juntunen
> GIS Specialist
> Polar Geospatial Center
> R280 Learning and Environmental Science
> 1954 Buford Ave
> University of Minnesota
> St. Paul, MN 55108
> 612-626-0505
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20200608/725f5e51/attachment-0001.html>
