[gdal-dev] MSSQLSpatial not using BCP to load
Rahkonen Jukka (MML) jukka.rahkonen at maanmittauslaitos.fi
Mon Jun 29 07:39:08 PDT 2020
Pity, I thought it would be simple but in your case avoiding -skipfailures is obviously not enough.
Please use “reply to all” on this mailing list, otherwise mail does not reach the list.
-Jukka Rahkonen-
Lähettäjä: Hector muro <muro.hector at gmail.com>
Lähetetty: maanantai 29. kesäkuuta 2020 17.28
Vastaanottaja: Rahkonen Jukka (MML) <jukka.rahkonen at maanmittauslaitos.fi>
Aihe: Re: [gdal-dev] MSSQLSpatial not using BCP to load
Thanks for that. I removed the argument but the process still loads one-by-one and does not seem to use BCP...
Regards
Hector
On Mon, 29 Jun 2020 at 15:10, jratike80 <jukka.rahkonen at maanmittauslaitos.fi<mailto:jukka.rahkonen at maanmittauslaitos.fi>> wrote:
Don't use -skipfailures. It is only possible to skip errors one by one if
transactions also contain just one row. It is even documented in the
Performance hints in https://gdal.org/programs/ogr2ogr.html.
-Jukka Rahkonen-
hectormauer wrote
> Hi,
> As a part of a project I need to load quite big geojsons into SQL Server
> and I am using ogr2ogr to do so.
> Here is an example command I am using:
> ogr2ogr -f MSSQLSpatial
> "MSSQL:server=xxx;database=xxx;UID=xxx;PWD=xxx;DRIVER={ODBC Driver 17 for
> SQL Server}" -append --config SPATIAL_INDEX NO --config
> MSSQLSPATIAL_USE_BCP TRUE --config MSSQLSPATIAL_BCP_SIZE 10000 --config
> MSSQLSPATIAL_USE_GEOMETRY_COLUMNS NO -nln INM.nv_lv_ohline -nlt GEOMETRY
> -t_srs EPSG:27700 -s_srs EPSG:4326 -skipfailures -splitlistfields
> $DATA/data.json
> I found that it is very slow and I have been checking the SQL Server
> profiler (as suggested already in this thread:
> https://lists.osgeo.org/pipermail/gdal-dev/2018-May/048520.html) and I can
> confirm that it is trying to insert every record one-by-one, hence the
> slowness.
> What I can't get to understand is how to point gdal to my sql server
> installation.
> SQL Server version: 2016
> GDAL: 3.0.4
> Thanks and regards,
> Hector Muro
> gdal-dev mailing list
> gdal-dev at .osgeo<mailto:gdal-dev at .osgeo>
> https://lists.osgeo.org/mailman/listinfo/gdal-dev
Sent from: http://osgeo-org.1560.x6.nabble.com/GDAL-Dev-f3742093.html
gdal-dev at lists.osgeo.org<mailto:gdal-dev at lists.osgeo.org>
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20200629/888cb01d/attachment.html>
