[gdal-dev] GDAL 3.1.2: PROJ_DEBUG
Daniel Mellergård daniel.mellergardh at gmail.com
Tue Nov 17 06:04:06 PST 2020
I was a bit eager to hit send... The GDAL version I am using is 3.0.4.
Den tis 17 nov. 2020 kl 14:01 skrev Daniel Mellergård <
daniel.mellergardh at gmail.com>:
> Hi,
> Is setting the environment variable PROJ_DEBUG=3 supposed to work when
> using GDAL3.1.2? Running for example gdalsrsinfo with that environment
> variable set has no effect, but running projinfo (from proj 6.3.2) does.
> I assume this has something to do with different "contexts" in Proj?
> Also, by programmatically using proj_log_level, I can see that the log
> level has been picked up by Proj in the default context.
> BR,
> Daniel
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20201117/27e0bf26/attachment.html>
