[gdal-dev] GDAL 3.1.2: PROJ_DEBUG
Daniel Mellergård daniel.mellergardh at gmail.com
Tue Nov 17 06:08:02 PST 2020
At the same time, can I assume OSRSetPROJSearchPaths to work as expected,
or is there any similar issue?
Den tis 17 nov. 2020 kl 14:04 skrev Daniel Mellergård <
daniel.mellergardh at gmail.com>:
> I was a bit eager to hit send... The GDAL version I am using is 3.0.4.
> Den tis 17 nov. 2020 kl 14:01 skrev Daniel Mellergård <
>> Hi,
>> Is setting the environment variable PROJ_DEBUG=3 supposed to work when
>> using GDAL3.1.2? Running for example gdalsrsinfo with that environment
>> variable set has no effect, but running projinfo (from proj 6.3.2) does.
>> I assume this has something to do with different "contexts" in Proj?
>> Also, by programmatically using proj_log_level, I can see that the log
>> level has been picked up by Proj in the default context.
>> BR,
>> Daniel
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20201117/93268dc4/attachment.html>
