[gdal-dev] GDAL 3.1.4 RC1 available
Even Rouault even.rouault at spatialys.com
Tue Oct 20 07:07:51 PDT 2020
On mardi 20 octobre 2020 11:27:13 CEST Joaquim Manuel Freire Luís wrote:
> Even,
> I don't think that was the case. I use a build system that resemble a bit
> homebrew. All packages are built in their own directories and SATAY there.
> Then I have a batch that creates symlinks do a directory that is the only
> in the computer path for my builds. So when I rebuild any package it gets
> automatically updated in my machine. Yes I did rebuild PROJ and GDAL from
> master as I always do and the problem arise but when I reverted PROJ to a
> commit only 9 days older (d1a0d95da549f7d32bcd8be408afe1fca62a6fb2), the
> problem disappeared.
I have no explanation for your issue but
https://github.com/rouault/gdal/runs/1280973974?check_suite_focus=true
( https://github.com/rouault/gdal/blob/
424c570530bc9725cf7391d023ffbb72edf85ebb/.github/workflows/windows_build.yml )
is an example of a successful Windows build with both PROJ and GDAL masters.
Even
http://www.spatialys.com
