[gdal-dev] GDAL 3.1.4 RC1 available
Joaquim Manuel Freire Luís jluis at ualg.pt
Tue Oct 20 07:30:28 PDT 2020
Well,
Mine also built correctly. It was on usage that the problem surfaced.
-----Original Message-----
Sent: Tuesday, October 20, 2020 3:08 PM
To: Joaquim Manuel Freire Luís <jluis at ualg.pt>
Cc: gdal-dev at lists.osgeo.org
Subject: Re: [gdal-dev] GDAL 3.1.4 RC1 available
On mardi 20 octobre 2020 11:27:13 CEST Joaquim Manuel Freire Luís wrote:
> Even,
> I don't think that was the case. I use a build system that resemble a
> bit homebrew. All packages are built in their own directories and SATAY there.
> Then I have a batch that creates symlinks do a directory that is the
> only in the computer path for my builds. So when I rebuild any package
> it gets automatically updated in my machine. Yes I did rebuild PROJ
> and GDAL from master as I always do and the problem arise but when I
> reverted PROJ to a commit only 9 days older
> (d1a0d95da549f7d32bcd8be408afe1fca62a6fb2), the problem disappeared.
I have no explanation for your issue but https://github.com/rouault/gdal/runs/1280973974?check_suite_focus=true
( https://github.com/rouault/gdal/blob/
424c570530bc9725cf7391d023ffbb72edf85ebb/.github/workflows/windows_build.yml ) is an example of a successful Windows build with both PROJ and GDAL masters.
Even
Spatialys - Geospatial professional services http://www.spatialys.com
