[gdal-dev] WMTS error with EPSG:3857
Even Rouault even.rouault at spatialys.com
Thu Sep 9 03:27:37 PDT 2021
Elena,
I believe the GetCapabilities response of this service is not fully
valid. The layer has a <TileMatrixSetLink> that points to a EPSG:3857
tileMatrix, but there's no <TileMatrixSet> definition with a
<ows:Identifier> with this value. You can presumably use the
GoogleMapsCompatible tilematrixset, which should be an alias of EPSG:3857
I've submitted in https://github.com/OSGeo/gdal/pull/4457 a fix to not
list that tilematrixset.
Even
Le 09/09/2021 à 11:54, Elena Ruiz a écrit :
> Hello, I do not understand the error that I get now when making a call
> to a WMTS service, before it worked correctly, also the EPSG: 3857 is
> supported by that service. Could someone tell me what this error is
> due to?
> >*gdalinfo
> "WMTS:http://www.ign.es/wmts/pnoa-ma?request=GetCapabilities&service=WMTS&username=&password=,layer=OI.OrthoimageCoverage,tilematrixset=EPSG:3857"*
> ERROR 1: Cannot find TileMatrixSet 'EPSG:3857'
> gdalinfo failed - unable to open
> 'WMTS:http://www.ign.es/wmts/pnoa-ma?request=GetCapabilities&service=WMTS&username=&password=,layer=OI.OrthoimageCoverage,tilematrixset=EPSG:3857'.
> Thank you and regards
> *Elena Ruiz *
> Sofware Development & Technical Support
> Tel. +34 952 43 97 71
> eruiz at aplitop.com
> Sumatra, 9 - 29190 Málaga (Spain)
> *www.aplitop.com
> <https://www.facebook.com/AplitopSL/> <https://twitter.com/aplitop>
> <https://www.linkedin.com/company/aplitop>
> <https://www.youtube.com/user/aplitop>*
> In accordance with the provisions of the European Regulation of Data
> Protection 2016/679 (Reglamento Europeo de Protección de Datos
> 2016/679), we inform you that the data and the information you provide
> us through this medium will be used by APLITOP, S.L., with C.I.F.
> B-92543396 and with address at C / Sumatra, 9, Malaga, 29190, in order
> to answer your questions and inform you about our products. The data
> provided will be kept as long as it does not request its cessation and
> will not be transferred to third parties except in cases where there
> is a legal obligation. You have the right to access your personal
> data, correct inaccurate data or request its deletion when the data is
> no longer necessary for the purposes that were collected, as well as
> any rights recognized in the RGPD 2016/679
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/gdal-dev
http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20210909/b772719c/attachment.html>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20210909/b772719c/attachment.png>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20210909/b772719c/attachment-0001.png>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20210909/b772719c/attachment-0002.png>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20210909/b772719c/attachment-0003.png>
