[gdal-dev] determine default SQL dialect
Even Rouault even.rouault at spatialys.com
Tue Aug 2 09:30:30 PDT 2022
Le 02/08/2022 à 18:25, Even Rouault a écrit :
> Le 02/08/2022 à 09:42, Michael Sumner a écrit :
>> Is it possible to determine the default SQL dialect  that will be
>> used in the C++ API?
> Short answer: no
> Long answer: for a driver that is backed by a SQL engine (SQLite,
> GPKG, PG, MySQL, OCI, etc.), it will default to the RDBMS SQL engine,
> otherwise to OGR SQL.
Potential not so pretty way of knowing if the default SQL dialect is OGR
SQL:
run ExecuteSQL( "SELECT OGR_GEOM_WKT FROM {some_layer_name}" )
if that works, then at 99.99% , you have OGR SQL.
Even
http://www.spatialys.com
