[gdal-dev] Creating a vector mbtile with several layers
DELEPINE Christophe christophe.delepine at thalesgroup.com
Thu Aug 18 08:03:26 PDT 2022
Hello
I want to implement a vector mbtile viewer and am considering using gdal to extract the data.
I am wondering if gdal public API allows to :
-   Retrieve metadata such as :
o   the min and max zoom levels for each layer
o   the min and max tile indexes for each layer and zoom level
-   Extract efficiently all the features of a given tile (with specific x/y indexes) at a given zoom level
I am currently reading the MBTILES implementation source code (mbtilesdataset.cpp) and there seems to be quite a lot of tricks internally (for instance with SetSpatialFilter)
Would somebody have an example using gdal to extract efficiently a tile for a given layer, given tile index and given zoom ?
Regards
Christophe
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20220818/d086c0a0/attachment.htm>
