[gdal-dev] JPEG2000 via range request
Martin e11904212 at student.tuwien.ac.at
Fri Aug 26 04:56:42 PDT 2022
I want to process JP2 data via vsicurl. Which works so far.
Unfortunately hundreds of requests are sent, even if only the data of
one tile is required.
I understand that due to the structure of a JP2 file multiple requests
are necessary. But it looks like GDAL is searching every single tile
(resulting in ~120 requests).
Is there a way to reduce the number of requests?
I have already tried the JP2ECW-ERDAS driver, same result.
Do I have to configure GDAL in a certain way?
cmd for request:
     #!/bin/bash
     export GDAL_DISABLE_READDIR_ON_OPEN="YES"
     export CPL_VSIL_CURL_ALLOWED_EXTENSIONS="jp2"
     export CPL_CURL_VERBOSE="YES"
     export GDAL_HTTP_MERGE_CONSECUTIVE_RANGES="YES"
     gdal_translate --debug ON -srcwin 0 0 256 256
/vsicurl/http://localhost:8083/T33UWP_20220515T100031_TCI_10m_J2Lmin.jp2
./out_subWin.tif
What options do I need to specify when creating the JP2 file to support
GDAL?
Currently I use the following options:
     #!/bin/bash
     gdal_translate \
         -of JP2OpenJPEG \
         -co QUALITY=100 \
         -co TLM=YES \
         -co PLT=YES \
         -co PROGRESSION=LRCP \
         -co WRITE_METADATA=YES \
         ../test_data/T33UWP_20220515T100031_TCI_10m.tif \
         ./T33UWP_20220515T100031_TCI_10m_J2Lmin.jp2
Some logs:
[gdal degug output](https://pastebin.com/vTf7tjLJ)
[nginx logs](https://pastebin.com/8bWW15Tp)
[gdalinfo](https://pastebin.com/HWSmypEQ)
[opj_dump](https://pastebin.com/rdYbHEnY)
[kdu_jp2info](https://pastebin.com/atVUfeVx)
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20220826/a34348b4/attachment.htm>
