[gdal-dev] Can't open postgrest service with ogr2ogr (via QGIS)
SIGéal sigeal at sigeal.com
Tue Feb 15 02:18:06 PST 2022
And I finally discovered that I can load my geojson webservice in QGIS
from Python :
myLayer= QgsVectorLayer('http://mydomain:3000/rpc/wod_geojson,
'myLayer', 'ogr')
QgsProject.instance().addMapLayers([myLayer])
But still not from QGIS UI...
Christophe Damour
Le 15/02/2022 à 10:38, SIGéal a écrit :
> I managed to have ogrinfo working by adding "Accept: application/json"
> header using GDAL_HTTP_HEADER_FILE.
> Now the problem is I can't do that with QGIS...
> Christophe Damour
> Le 15/02/2022 à 08:46, Rahkonen Jukka (MML) a écrit :
>> Hi,
>> I wonder if there could be something in the Accept headers that
>> orginfo is using.  Ogrinfo seems to set headers “Accept: text/plain,
>> application/json” but GeoJSON is now officially
>> “application/geo+json”. I do not know the hierarchy of the MIME types
>> and if “json” should include also the subtype “geo+json”.
>> I made a test with ogrinfo and  --config GDAL_HTTP_HEADER_FILE
>> my_headers.txt. After this I could see from the logs this
>> Accept: application/geo+json
>> Accept: text/plain, application/json
>> By https://datatracker.ietf.org/doc/html/rfc2616/ I suppose this is
>> correct and http server should concatenate Accept headers. However,
>> the test was not successful so maybe there is something else going wrong.
>> -Jukka Rahkonen-
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20220215/6fcce76a/attachment.html>
