[gdal-dev] Can't open postgrest service with ogr2ogr (via QGIS)
SIGéal sigeal at sigeal.com
Tue Feb 15 01:38:31 PST 2022
I managed to have ogrinfo working by adding "Accept: application/json"
header using GDAL_HTTP_HEADER_FILE.
Now the problem is I can't do that with QGIS...
Christophe Damour
Le 15/02/2022 à 08:46, Rahkonen Jukka (MML) a écrit :
> Hi,
> I wonder if there could be something in the Accept headers that
> orginfo is using.  Ogrinfo seems to set headers “Accept: text/plain,
> application/json” but GeoJSON is now officially
> “application/geo+json”. I do not know the hierarchy of the MIME types
> and if “json” should include also the subtype “geo+json”.
> I made a test with ogrinfo and  --config GDAL_HTTP_HEADER_FILE
> my_headers.txt. After this I could see from the logs this
> Accept: application/geo+json
> Accept: text/plain, application/json
> By https://datatracker.ietf.org/doc/html/rfc2616/ I suppose this is
> correct and http server should concatenate Accept headers. However,
> the test was not successful so maybe there is something else going wrong.
> -Jukka Rahkonen-
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20220215/34014b54/attachment.html>
