[gdal-dev] Gdal_translate into HDF4 fails
Rahkonen Jukka (MML) jukka.rahkonen at maanmittauslaitos.fi
Fri Feb 18 06:33:55 PST 2022
That HDF5 driver is read-only is documented in https://gdal.org/drivers/raster/hdf5.html so that the driver capabilities are missing Supports CreateCopy() and Supports Create()
Same metadata is available with gdalinfo --format [format_name].
(But metadata is wrong for HDF4 and capabilities are missing, I wonder how to fix that)
gdalinfo --format hdf4
Format Details:
  Short Name: HDF4
  Long Name: Hierarchical Data Format Release 4
  Supports: Raster
  Supports: Multidimensional raster
  Extension: hdf
  Help Topic: drivers/raster/hdf4.html
  Supports: Raster subdatasets
  Supports: Open() - Open existing dataset.
-Jukka Rahkonen-
Lähettäjä: Lorenzo Di Giacomo <loridigia at gmail.com>
Lähetetty: perjantai 18. helmikuuta 2022 16.24
Vastaanottaja: Even Rouault <even.rouault at spatialys.com>
Kopio: Rahkonen Jukka (MML) <jukka.rahkonen at maanmittauslaitos.fi>; 'gdal-dev at lists.osgeo.org' (gdal-dev at lists.osgeo.org) <gdal-dev at lists.osgeo.org>
Aihe: Re: [gdal-dev] Gdal_translate into HDF4 fails
Hi guys, i was reading the question and i was wondering if it's possibile do the same translate operation with HDF5, like:
gdal_translate -of HDF5Image 3band.tif out.h5, i tried but doesn't work and says "
HDF5 driver has no creation capabilities."
Thanks
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20220218/9f23199d/attachment.html>
