[gdal-dev] Use GitPod for GDAL?
Matt Wilkie maphew at gmail.com
Fri Feb 18 14:34:19 PST 2022
This what I've come up with:
https://gitpod.io
Create new >> search for gdal >> select OSGeo/gdal
On launch:
-- Could NOT find PROJ (missing: PROJ_DIR)
CMake Error at
/home/linuxbrew/.linuxbrew/Cellar/cmake/3.22.2/share/cmake/Modules/FindPackageHandleStandardArgs.cmake:230
(message):
  Could NOT find PROJ (missing: PROJ_LIBRARY PROJ_INCLUDE_DIR) (Required is
  at least version "6.0")
Call Stack (most recent call first):
  /home/linuxbrew/.linuxbrew/Cellar/cmake/3.22.2/share/cmake/Modules/FindPackageHandleStandardArgs.cmake:594
(_FPHSA_FAILURE_MESSAGE)
  cmake/modules/packages/FindPROJ.cmake:57
(find_package_handle_standard_args)
  cmake/helpers/CheckDependentLibraries.cmake:303 (find_package)
  gdal.cmake:210 (include)
  CMakeLists.txt:206 (include)
Attempted to remedy this with `sudo apt install proj-bin` but same error
from `cmake .`
The below adapted from
https://github.com/maphew/gdal/blob/pr-5281-redux/CONTRIBUTING.md
cd /workspace/gdal
./autogen.sh
./configure --with-python
Fails with "configure: error: PROJ 6 symbols not found".
tried `sudo apt install proj-bin` and repeated above, same error.
Version of proj that's installed with this is 6.3.1.
Try building Proj from source (takes awhile):
cd /workspace
wget https://download.osgeo.org/proj/proj-6.3.1.tar.gz
tar zxf proj-*.gz
cd proj-6.3.1
./configure
make && sudo make install
Now try again (takes much longer):
cd /workspace/gdal
./autogen.sh
make -j8
sudo make install
It works!
. scripts/setdevenv.sh
gdalinfo --version
GDAL 3.5.0dev-39057d7396, released 2022/02/18
uname -a
inux osgeo-gdal-j6a7bhjf0c8 5.13.0-1013-gcp #16-Ubuntu SMP Tue Jan 18
14:31:35 UTC 2022 x86_64 x86_64 x86_64 GNU/Linux
I'm still unable to successfully install a python wheel of gdal-utils,
because pip is calling g++ which in turn is not finding libgdal, but it
still feels like significant progress to get this far! :)
-matt
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20220218/0a97a2da/attachment-0001.html>
