[gdal-dev] "tolerance condition error" on reprojecting natural earth data to webmercator (3857)
Adam Akhtar adamsubscribe at googlemail.com
Fri Feb 25 23:15:52 PST 2022
Sorry for the slow reply Even,
I just tried this now and it seems to have worked. Thank you very much for
you help on this matter.
For posterity and other's benefit I modified my original command to include
-clipsrc -180.1 -85.0511 180.1 85.0511
i.e.
OGR_ENABLE_PARTIAL_REPROJECTION=true ogr2ogr -unsetFieldWidth -t_srs
EPSG:3857 -clipsrc -180.1 -85.0511 180.1 85.0511 -nlt PROMOTE_TO_MULTI -f
PostgreSQL PG:"dbname='ogr' host='localhost' port='5432' user='myusername
password='redacted'" ne_10m_ocean.shp
Thanks again
Adam
On Tue, 22 Feb 2022 at 20:47, Even Rouault <even.rouault at spatialys.com>
wrote:
> This dataset includes latitude up to 90 degree north, which projects to
> infinity in EPSG:3857. You should use the -clipsrc option of ogr2ogr to for
> example cut at 85 degree
> Le 21/02/2022 à 10:14, Adam Akhtar via gdal-dev a écrit :
> Hi,
> I'm getting a "tolerance condition error" when trying to reproject Natural
> Earth data into webmercator 3857 using ogr2ogr.
> These are the commands I am running
> wget https://naturalearth.s3.amazonaws.com/10m_physical/ne_10m_ocean.zip
> unzip ne_10m_ocean.zip
> // reproject the unzipped shape file
> EPSG:3857 -nlt PROMOTE_TO_MULTI -f PostgreSQL PG:"dbname='ogr'
> host='localhost' port='5432' user='myusername password='redacted'"
> ne_10m_ocean.shp
> This results in the following output
> ERROR 1: tolerance condition error
> ERROR 1: Reprojection failed, err = -20, further errors will be suppressed
> on the transform object.
> I'm sure this used to run fine a few months ago so I'm not sure why it is
> suddenly breaking.
> This happens on both my arm Mac and my Intel server instance.
> Server instance:
> EC2 M5 Intel with Ubuntu 20.04.3 LTS
> GDAL 3.3.2, released 2021/09/01
> Mac
> M1 Arm Mac Big Sur 11.6
> GDAL 3.3.3, released 2021/10/25
> Is this or a bug or am I incorrectly using the command? Any help will be
> greatly appreciated.
> Adam
> gdal-dev mailing listgdal-dev at lists.osgeo.orghttps://lists.osgeo.org/mailman/listinfo/gdal-dev
> -- http://www.spatialys.com
> My software is free, but my time generally not.
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20220226/711732c2/attachment.html>
