[gdal-dev] GDAL 3.5.0rc4 available (Re: GDAL 3.5.0 release candidate available)
Sean Gillies sean.gillies at gmail.com
Tue May 10 15:10:27 PDT 2022
I agree that this seems more likely to be an issue with PROJ. I found
suggestions from Mike Taves in the PROJ project and am following them.
I'm trying GDAL 3.5.0rc4 with PROJ 8.2.1 and will follow up in an hour.
On Tue, May 10, 2022 at 3:33 PM Even Rouault <even.rouault at spatialys.com>
wrote:
> Sean,
> So your issue is with a GDAL autoconf build. I can't see any significant
> changes in configure.ac between GDAL 3.5.0 and 3.4.0 related to rpath.
> This has probably not changed in years. I do see in your logs that the
> linking line of GDAL has a
>  -rpath /usr/local/lib
> and that there's a /usr/local/lib/libproj.25.dylib file
> But perhaps the issue is more with the PROJ CMake build (hypothesis that
> you could check by testing with a PROJ 8.2.1 autoconf build) ? I don't
> know... Mac + rpath is hostile territory for me.
> Does running a GDAL binary, like gdalinfo, works before using that
> delocate module ?
> Yes 5413 is CMake specific.
> Even
> Le 10/05/2022 à 23:02, Sean Gillies a écrit :.
> Hi Even,
> I'm running into a problem with GDAL 3.5.0rc4 and PROJ 9.0.0 on macos. It
> occurs when I use https://github.com/matthew-brett/delocate to relocate
> GDAL and its dependencies into rasterio wheels.
> The error:
> ERROR:delocate.libsana:
> @rpath/libproj.25.dylib not found:
> Needed by: /usr/local/lib/libgdal.31.dylib
> Search path:
> ERROR:delocate.libsana:@rpath/libproj.25.dylib not found, requested by
> Here is its context:
> https://github.com/rasterio/rasterio-wheels/runs/6375882173?check_suite_focus=true#step:4:4025
> I searched the GDAL tracker for related issues and only found
> https://github.com/OSGeo/gdal/issues/5413. It looks like it could be
> related, but it also looks like the fix is cmake specific and isn't
> available for autotools builds. Is that correct?
> On Tue, May 10, 2022 at 8:13 AM Even Rouault <even.rouault at spatialys.com>
> wrote:
>> Hi,
>> I've issued a rc4 with the following fixes w.r.t rc3:
>> * fix build error with CMake >= 3.10.2 and < 3.11
>> * fix build errors with Fedora mingw32
>> Updated archives:
>>    https://download.osgeo.org/gdal/3.5.0/gdal-3.5.0rc4.tar.xz
>>    https://download.osgeo.org/gdal/3.5.0/gdal-3.5.0rc4.tar.gz
>>    https://download.osgeo.org/gdal/3.5.0/gdal350rc4.zip
>> Even
>> Le 06/05/2022 à 15:06, Even Rouault a écrit :
>> > Hi,
>> > I have prepared a GDAL/OGR 3.5.0 release candidate.
>> > NEWS at:
>> >   https://github.com/OSGeo/gdal/blob/v3.5.0RC1/NEWS.md
>> > Note the first item about the new CMake build system, and the
>> > deprecation of the autoconf & nmake build systems that will be removed
>> > in GDAL 3.6.0
>> > Pick up an archive among the following ones (by ascending size):
>> >   https://download.osgeo.org/gdal/3.5.0/gdal-3.5.0rc1.tar.xz
>> >   https://download.osgeo.org/gdal/3.5.0/gdal-3.5.0rc1.tar.gz
>> >   https://download.osgeo.org/gdal/3.5.0/gdal350rc1.zip
>> > A snapshot of the gdalautotest suite is also available :
>> > https://download.osgeo.org/gdal/3.5.0/gdalautotest-3.5.0rc1.tar.gz
>> >   https://download.osgeo.org/gdal/3.5.0/gdalautotest-3.5.0rc1.zip
>> > A snapshot of the documentation is at:
>> >   https://download.osgeo.org/gdal/3.5.0/gdal350doc.zip
>> > The GDAL-GRASS plugin sources and release process has been moved to
>> > https://github.com/OSGeo/gdal-grass
>> > I'll call for a vote promoting it to next week if no serious problems
>> > are reported before.
>> > The "release/3.5" branch has been created for all bug fixes related to
>> > 3.5.x. master is now targetting 3.6.0dev.
>> > Best regards,
>> > Even
>> http://www.spatialys.com
>> My software is free, but my time generally not.
>> gdal-dev mailing list
>> gdal-dev at lists.osgeo.org
>> https://lists.osgeo.org/mailman/listinfo/gdal-dev
> Sean Gillies
> gdal-dev mailing listgdal-dev at lists.osgeo.orghttps://lists.osgeo.org/mailman/listinfo/gdal-dev
> -- http://www.spatialys.com
Sean Gillies
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20220510/055169fd/attachment-0001.htm>
