[gdal-dev] GDAL 3.5.0rc4 available (Re: GDAL 3.5.0 release candidate available)
Even Rouault even.rouault at spatialys.com
Wed May 11 02:25:54 PDT 2022
You mean setting rpath in LDFLAGS of PROJ or GDAL ?
CMake has a lot of tunings for RPATH, and some extra more for Mac  :
CMAKE_INSTALL_RPATH, CMAKE_SKIP_RPATH,
CMAKE_INSTALL_RPATH_USE_LINK_PATH, MACOSX_RPATH etc. . Users might need
to tune them depending on their use cases. In
https://github.com/OSGeo/PROJ/commit/e1253e4b09d4260acc541acf15967356419197c9
that went to 9.0.0, we've removed most RPATH releated overrides to just
let CMake defaults, so users can tune them more freely.
Le 11/05/2022 à 02:59, Sean Gillies a écrit :
> Explicitly setting rpath in LDFLAGS solved my PROJ 9 problem. This
> feels like a regression. It isn't necessary for Linux and wasn't
> necessary for autotools builds of PROJ 8.2.1.
> Back on topic: GDAL 3.5.0rc4 seems fine.
> On Tue, May 10, 2022, 4:18 PM Sean Gillies <sean.gillies at gmail.com> wrote:
>     Thanks, Alan!
>     I feel like we're in the middle of going backwards to go forwards
>     when it comes to FOSS4G software builds.
>     On Tue, May 10, 2022 at 4:05 PM Alan Snow <alansnow21 at gmail.com>
>     wrote:
>         This might be a helpful reference:
>         https://github.com/pyproj4/pyproj-wheels/issues/45
>         On Tue, May 10, 2022, 4:33 PM Even Rouault
>         <even.rouault at spatialys.com> wrote:
>             Sean,
>             So your issue is with a GDAL autoconf build. I can't see
>             any significant changes in configure.ac
>             <http://configure.ac> between GDAL 3.5.0 and 3.4.0 related
>             to rpath. This has probably not changed in years. I do see
>             in your logs that the linking line of GDAL has a
>              -rpath /usr/local/lib
>             and that there's a /usr/local/lib/libproj.25.dylib file
>             But perhaps the issue is more with the PROJ CMake build
>             (hypothesis that you could check by testing with a PROJ
>             8.2.1 autoconf build) ? I don't know... Mac + rpath is
>             hostile territory for me.
>             Does running a GDAL binary, like gdalinfo, works before
>             using that delocate module ?
>             Yes 5413 is CMake specific.
>             Even
>             Le 10/05/2022 à 23:02, Sean Gillies a écrit :.
>>             Hi Even,
>>             I'm running into a problem with GDAL 3.5.0rc4 and PROJ
>>             9.0.0 on macos. It occurs when I use
>>             https://github.com/matthew-brett/delocate to relocate
>>             GDAL and its dependencies into rasterio wheels.
>>             The error:
>>             ERROR:delocate.libsana:
>>             @rpath/libproj.25.dylib not found:
>>             Needed by: /usr/local/lib/libgdal.31.dylib
>>             Search path:
>>             ERROR:delocate.libsana:@rpath/libproj.25.dylib not found,
>>             requested by /usr/local/lib/libgdal.31.dylib
>>             Here is its context:
>>             https://github.com/rasterio/rasterio-wheels/runs/6375882173?check_suite_focus=true#step:4:4025.
>>             I searched the GDAL tracker for related issues and only
>>             found https://github.com/OSGeo/gdal/issues/5413. It looks
>>             like it could be related, but it also looks like the fix
>>             is cmake specific and isn't available for autotools
>>             builds. Is that correct?
>>             On Tue, May 10, 2022 at 8:13 AM Even Rouault
>>                 Hi,
>>                 I've issued a rc4 with the following fixes w.r.t rc3:
>>                 * fix build error with CMake >= 3.10.2 and < 3.11
>>                 * fix build errors with Fedora mingw32
>>                 Updated archives:
>>                 https://download.osgeo.org/gdal/3.5.0/gdal-3.5.0rc4.tar.xz
>>                 https://download.osgeo.org/gdal/3.5.0/gdal-3.5.0rc4.tar.gz
>>                 https://download.osgeo.org/gdal/3.5.0/gdal350rc4.zip
>>                 Even
>>                 Le 06/05/2022 à 15:06, Even Rouault a écrit :
>>                 > Hi,
>>                 > I have prepared a GDAL/OGR 3.5.0 release candidate.
>>                 > NEWS at:
>>                 > https://github.com/OSGeo/gdal/blob/v3.5.0RC1/NEWS.md
>>                 > Note the first item about the new CMake build
>>                 system, and the
>>                 > deprecation of the autoconf & nmake build systems
>>                 that will be removed
>>                 > in GDAL 3.6.0
>>                 > Pick up an archive among the following ones (by
>>                 ascending size):
>>                 https://download.osgeo.org/gdal/3.5.0/gdal-3.5.0rc1.tar.xz
>>                 https://download.osgeo.org/gdal/3.5.0/gdal-3.5.0rc1.tar.gz
>>                 > https://download.osgeo.org/gdal/3.5.0/gdal350rc1.zip
>>                 > A snapshot of the gdalautotest suite is also
>>                 available :
>>                 https://download.osgeo.org/gdal/3.5.0/gdalautotest-3.5.0rc1.tar.gz
>>                 https://download.osgeo.org/gdal/3.5.0/gdalautotest-3.5.0rc1.zip
>>                 > A snapshot of the documentation is at:
>>                 > https://download.osgeo.org/gdal/3.5.0/gdal350doc.zip
>>                 > The GDAL-GRASS plugin sources and release process
>>                 has been moved to
>>                 > https://github.com/OSGeo/gdal-grass
>>                 > I'll call for a vote promoting it to next week if
>>                 no serious problems
>>                 > are reported before.
>>                 > The "release/3.5" branch has been created for all
>>                 bug fixes related to
>>                 > 3.5.x. master is now targetting 3.6.0dev.
>>                 > Best regards,
>>                 > Even
>>                 http://www.spatialys.com
>>                 My software is free, but my time generally not.
>>                 _______________________________________________
>>                 gdal-dev mailing list
>>                 gdal-dev at lists.osgeo.org
>>                 https://lists.osgeo.org/mailman/listinfo/gdal-dev
>>             Sean Gillies
>     Sean Gillies
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20220511/f686c429/attachment-0001.htm>
