[gdal-dev] Reading NetCDF files from EPA RSIG
Even Rouault even.rouault at spatialys.com
Wed May 11 11:07:52 PDT 2022
Kodi,
this is indeed a netCDF file, but not a gridded one. It is recgonized by
the vector side of GDAL (ogrinfo) as a layer of points. You could use it
as the input of the gdal_grid utility to create a gridded raster file
Even
Le 11/05/2022 à 19:55, Kodi Arfer a écrit :
> Looking at some NetCDF files produced by EPA RSIG, which is described at
> https://www.epa.gov/hesc/web-access-rsig-data
> I've found that GDAL 3.4.3 doesn't recognize them as readable at all
> ("ERROR 4: `rsig.nc' not recognized as a supported file format."),
> although I can open them with e.g. the R library `ncdf4`. You can get
> a 400-kb example file at
> https://ofmpub.epa.gov/rsig/rsigserver?SERVICE=wcs&VERSION=1.0.0&REQUEST=GetCoverage&COVERAGE=tropomi.offl.no2.nitrogendioxide_tropospheric_column&minimum_quality=50&BBOX=-70,24,-65,30&TIME=2019-11-01T00:00:00Z/2019-11-01T23:00:00Z&FORMAT=netcdf-coards
> I spoke to an administrator of the service and he believes that valid
> NetCDF is being produced. Any idea what's going on?
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/gdal-dev
http://www.spatialys.com
