[gdal-dev] Reading NetCDF files from EPA RSIG
Kodi Arfer research at arfer.net
Wed May 11 11:35:30 PDT 2022
On 2022-05-11 2:07 PM -0400, Even Rouault wrote:
> Le 11/05/2022 à 19:55, Kodi Arfer a écrit :
>> Looking at some NetCDF files produced by EPA RSIG, which is described at
>> https://www.epa.gov/hesc/web-access-rsig-data
>> I've found that GDAL 3.4.3 doesn't recognize them as readable at all
>> ("ERROR 4: `rsig.nc' not recognized as a supported file format.")
> this is indeed a netCDF file, but not a gridded one. It is recgonized by
> the vector side of GDAL (ogrinfo) as a layer of points.
I see. Thanks for the explanation. Is `gdalinfo` producing the right
error message for this case, or is that a bug?
