[gdal-dev] Ogrinfo , ogr2ogr file size limits
Gonzalez Velasquez, Frando Alexis fagonzalezv at indracompany.com
Mon May 16 19:21:23 PDT 2022
Hi dev team!
I am writing to inquire about big files problem,
We are using the ogrinfo and ogr2ogr executables over small files with success (1 gb max)  but with 10 gb files we are experiencing memory problems and and it does not work, is there a file size limit? And if there is a size limit, is there any strategy to handle this problema and process big files with success ?
For example:
ogrinfo -q -so C:\\tmp\\file.xtf
When file is 1Gb success ; but when  the file is 10gb size the process fails.
Any advice would be appreciated, thanks.
[minsait-indra]
FRANDO GONZÁLEZ
Senior Systems Engineer
fagonzalezv at indracompany.com<mailto:fagonzalezv at indracompany.com>
Calle 93 16 25
Bogotá, Colombia
T +57 1 646 36 00
M +57 3006604908
minsait.com<https://eur04.safelinks.protection.outlook.com/?url=http%3A%2F%2Fwww.minsait.com%2F&data=04%7C01%7Cfagonzalezv%40indracompany.com%7C6c419c97a7134841c0da08d9f7ce4282%7C7808e00514894374954bd3b08f193920%7C0%7C0%7C637813287514711623%7CUnknown%7CTWFpbGZsb3d8eyJWIjoiMC4wLjAwMDAiLCJQIjoiV2luMzIiLCJBTiI6Ik1haWwiLCJXVCI6Mn0%3D%7C3000&sdata=0Jr%2BkI3f3Uh3g%2FG5C5yElQX9pHauhEi9ds6w%2FPOxLtM%3D&reserved=0>
indracompany.com<https://eur04.safelinks.protection.outlook.com/?url=http%3A%2F%2Fwww.indracompany.com%2F&data=04%7C01%7Cfagonzalezv%40indracompany.com%7C6c419c97a7134841c0da08d9f7ce4282%7C7808e00514894374954bd3b08f193920%7C0%7C0%7C637813287514711623%7CUnknown%7CTWFpbGZsb3d8eyJWIjoiMC4wLjAwMDAiLCJQIjoiV2luMzIiLCJBTiI6Ik1haWwiLCJXVCI6Mn0%3D%7C3000&sdata=W2xsw4RMlZ8TUymKMTE5zqosvKN2LV5QhwvGmAxgZM0%3D&reserved=0>
Este correo electrónico y, en su caso, cualquier fichero anexo al mismo, contiene información de carácter confidencial exclusivamente dirigida a su destinatario o destinatarios. Si no es vd. el destinatario indicado, queda notificado que la lectura, utilización, divulgación y/o copia sin autorización está prohibida en virtud de la legislación vigente. En el caso de haber recibido este correo electrónico por error, se ruega notificar inmediatamente esta circunstancia mediante reenvío a la dirección electrónica del remitente.
Evite imprimir este mensaje si no es estrictamente necesario.
This email and any file attached to it (when applicable) contain(s) confidential information that is exclusively addressed to its recipient(s). If you are not the indicated recipient, you are informed that reading, using, disseminating and/or copying it without authorisation is forbidden in accordance with the legislation in effect. If you have received this email by mistake, please immediately notify the sender of the situation by resending it to their email address.
Avoid printing this message if it is not absolutely necessary.
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20220517/10d027ee/attachment-0001.htm>
Type: image/png
Desc: image001.png
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20220517/10d027ee/attachment-0001.png>
