[gdal-dev] Ogrinfo , ogr2ogr file size limits
Even Rouault even.rouault at spatialys.com
Tue May 17 02:42:52 PDT 2022
Frando,
The .xtf extension doens't ring a bell to me. Which OGR driver
recognizes such file ? (remove the -q option and look at the beginning
of the report of ogrinfo), and what is your GDAL version ?
Most OGR drivers work in streaming mode and can handle arbitrary big
files, but a few ones have no other choice than ingesting the whole
file, in which case there's no workaround apart splitting the file with
other tools or buy more RAM
Even
Le 17/05/2022 à 04:21, Gonzalez Velasquez, Frando Alexis a écrit :
> Hi dev team!
> I am writing to inquire about big files problem,
> We are using the ogrinfo and ogr2ogr executables over small files with
> success (1 gb max)  but with 10 gb files we are experiencing memory
> problems and and it does not work, is there a file size limit? And if
> there is a size limit, is there any strategy to handle this problema
> and process big files with success ?
> For example:
> */ogrinfo -q -so C:\\tmp\\file.xtf /*
> When file is 1Gb success ; but when  the file is 10gb size the process
> fails.
> Any advice would be appreciated, thanks.
> minsait-indra
> FRANDO GONZÁLEZ
> Senior Systems Engineer
> fagonzalezv at indracompany.com <mailto:fagonzalezv at indracompany.com>
> Calle 93 16 25
> Bogotá, Colombia
> T +57 1 646 36 00
> M +57 3006604908
> minsait.com
> <https://eur04.safelinks.protection.outlook.com/?url=http%3A%2F%2Fwww.minsait.com%2F&data=04%7C01%7Cfagonzalezv%40indracompany.com%7C6c419c97a7134841c0da08d9f7ce4282%7C7808e00514894374954bd3b08f193920%7C0%7C0%7C637813287514711623%7CUnknown%7CTWFpbGZsb3d8eyJWIjoiMC4wLjAwMDAiLCJQIjoiV2luMzIiLCJBTiI6Ik1haWwiLCJXVCI6Mn0%3D%7C3000&sdata=0Jr%2BkI3f3Uh3g%2FG5C5yElQX9pHauhEi9ds6w%2FPOxLtM%3D&reserved=0>
> indracompany.com
> <https://eur04.safelinks.protection.outlook.com/?url=http%3A%2F%2Fwww.indracompany.com%2F&data=04%7C01%7Cfagonzalezv%40indracompany.com%7C6c419c97a7134841c0da08d9f7ce4282%7C7808e00514894374954bd3b08f193920%7C0%7C0%7C637813287514711623%7CUnknown%7CTWFpbGZsb3d8eyJWIjoiMC4wLjAwMDAiLCJQIjoiV2luMzIiLCJBTiI6Ik1haWwiLCJXVCI6Mn0%3D%7C3000&sdata=W2xsw4RMlZ8TUymKMTE5zqosvKN2LV5QhwvGmAxgZM0%3D&reserved=0>
> Este correo electrónico y, en su caso, cualquier fichero anexo al
> mismo, contiene información de carácter confidencial exclusivamente
> dirigida a su destinatario o destinatarios. Si no es vd. el
> destinatario indicado, queda notificado que la lectura, utilización,
> divulgación y/o copia sin autorización está prohibida en virtud de la
> legislación vigente. En el caso de haber recibido este correo
> electrónico por error, se ruega notificar inmediatamente esta
> circunstancia mediante reenvío a la dirección electrónica del remitente.
> Evite imprimir este mensaje si no es estrictamente necesario.
> This email and any file attached to it (when applicable) contain(s)
> confidential information that is exclusively addressed to its
> recipient(s). If you are not the indicated recipient, you are informed
> that reading, using, disseminating and/or copying it without
> authorisation is forbidden in accordance with the legislation in
> effect. If you have received this email by mistake, please immediately
> notify the sender of the situation by resending it to their email address.
> Avoid printing this message if it is not absolutely necessary.
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/gdal-dev
http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20220517/bfc61ab4/attachment.htm>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20220517/bfc61ab4/attachment.png>
