[gdal-dev] Ogrinfo , ogr2ogr file size limits
Joaquim Manuel Freire Luís jluis at ualg.pt
Tue May 17 02:53:06 PDT 2022
xtf is the extension by a format of sidescan sonar data.
This one was picked randomly from a google search
https://www.usna.edu/Users/oceano/pguth/md_help/html/sidescan.htm
From: gdal-dev <gdal-dev-bounces at lists.osgeo.org> On Behalf Of Even Rouault
Sent: Tuesday, May 17, 2022 10:43 AM
To: Gonzalez Velasquez, Frando Alexis <fagonzalezv at indracompany.com>; gdal-dev at lists.osgeo.org
Cc: Serrano Granados, Yency <yserrano at indracompany.com>
Subject: Re: [gdal-dev] Ogrinfo , ogr2ogr file size limits
Frando,
The .xtf extension doens't ring a bell to me. Which OGR driver recognizes such file ? (remove the -q option and look at the beginning of the report of ogrinfo), and what is your GDAL version ?
Most OGR drivers work in streaming mode and can handle arbitrary big files, but a few ones have no other choice than ingesting the whole file, in which case there's no workaround apart splitting the file with other tools or buy more RAM
Even
Le 17/05/2022 à 04:21, Gonzalez Velasquez, Frando Alexis a écrit :
Hi dev team!
I am writing to inquire about big files problem,
We are using the ogrinfo and ogr2ogr executables over small files with success (1 gb max)  but with 10 gb files we are experiencing memory problems and and it does not work, is there a file size limit? And if there is a size limit, is there any strategy to handle this problema and process big files with success ?
For example:
ogrinfo -q -so C:\\tmp\\file.xtf
When file is 1Gb success ; but when  the file is 10gb size the process fails.
Any advice would be appreciated, thanks.
[minsait-indra]
FRANDO GONZÁLEZ
Senior Systems Engineer
fagonzalezv at indracompany.com<mailto:fagonzalezv at indracompany.com>
Calle 93 16 25
Bogotá, Colombia
T +57 1 646 36 00
M +57 3006604908
minsait.com<https://eur04.safelinks.protection.outlook.com/?url=http%3A%2F%2Fwww.minsait.com%2F&data=04%7C01%7Cfagonzalezv%40indracompany.com%7C6c419c97a7134841c0da08d9f7ce4282%7C7808e00514894374954bd3b08f193920%7C0%7C0%7C637813287514711623%7CUnknown%7CTWFpbGZsb3d8eyJWIjoiMC4wLjAwMDAiLCJQIjoiV2luMzIiLCJBTiI6Ik1haWwiLCJXVCI6Mn0%3D%7C3000&sdata=0Jr%2BkI3f3Uh3g%2FG5C5yElQX9pHauhEi9ds6w%2FPOxLtM%3D&reserved=0>
indracompany.com<https://eur04.safelinks.protection.outlook.com/?url=http%3A%2F%2Fwww.indracompany.com%2F&data=04%7C01%7Cfagonzalezv%40indracompany.com%7C6c419c97a7134841c0da08d9f7ce4282%7C7808e00514894374954bd3b08f193920%7C0%7C0%7C637813287514711623%7CUnknown%7CTWFpbGZsb3d8eyJWIjoiMC4wLjAwMDAiLCJQIjoiV2luMzIiLCJBTiI6Ik1haWwiLCJXVCI6Mn0%3D%7C3000&sdata=W2xsw4RMlZ8TUymKMTE5zqosvKN2LV5QhwvGmAxgZM0%3D&reserved=0>
Este correo electrónico y, en su caso, cualquier fichero anexo al mismo, contiene información de carácter confidencial exclusivamente dirigida a su destinatario o destinatarios. Si no es vd. el destinatario indicado, queda notificado que la lectura, utilización, divulgación y/o copia sin autorización está prohibida en virtud de la legislación vigente. En el caso de haber recibido este correo electrónico por error, se ruega notificar inmediatamente esta circunstancia mediante reenvío a la dirección electrónica del remitente.
Evite imprimir este mensaje si no es estrictamente necesario.
This email and any file attached to it (when applicable) contain(s) confidential information that is exclusively addressed to its recipient(s). If you are not the indicated recipient, you are informed that reading, using, disseminating and/or copying it without authorisation is forbidden in accordance with the legislation in effect. If you have received this email by mistake, please immediately notify the sender of the situation by resending it to their email address.
Avoid printing this message if it is not absolutely necessary.
gdal-dev mailing list
gdal-dev at lists.osgeo.org<mailto:gdal-dev at lists.osgeo.org>
https://lists.osgeo.org/mailman/listinfo/gdal-dev
http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20220517/485feb71/attachment-0001.htm>
Type: image/png
Desc: image001.png
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20220517/485feb71/attachment-0001.png>
