[gdal-dev] Command line /python syntax differences
Even Rouault even.rouault at spatialys.com
Wed Nov 2 04:03:54 PDT 2022
Jonas,
The doc is at:
https://gdal.org/api/python/osgeo.gdal.html#osgeo.gdal.TranslateOptions
Even
Le 02/11/2022 à 11:53, Jonas Ardö via gdal-dev a écrit :
> Dear gdal-gurus,
> I am new to using gdal via Python.
> As the command line arguments/keywords differ from command prompt mode
> and Python-mode (for example for example is *-r* in gdal_translate
> the same  as *resampleAlg* in gdal.Translate in Python).
> I find it tricky to find arguments/keywords in Python.
> How can all options/full syntax for gdal-pythons commands be listed as
> done here
> <https://gis.stackexchange.com/questions/352643/gdal-translate-in-python-where-do-i-find-how-to-convert-the-command-line-argum>
> Where they also refer tohttps://gdal.org/python/ which do not exist.
> Any other (full/completed) online resource for this?
> Can "pydoc -g osgeo" be used?
> Are the The gdal-dev Archives searchable?
> Regards
> /Jonas, Lund University, Sweden
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/gdal-dev
http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20221102/be5ef93b/attachment.htm>
