[gdal-dev] Command line /python syntax differences
Jonas Ardö jonas.ardo at nateko.lu.se
Wed Nov 2 07:29:38 PDT 2022
Thanks Even,
Still some discrepancy.
*Python (don't work but no error and no output ):
*src_ds = gdal.Open("I:\indata\VPDsc\VPD_scalar.tif")
     #1 GDALWARP to warp all bands in one go
     options = gdal.WarpOptions(options=srcSRS="EPSG:4326",
dstSRS="EPSG:32628", xRes=20.0, yRes=20.0, resampleAlg="bilinear",
format='GTiff', outputBounds=[453123, 1702425, 454123, 1703425])
     newfile = gdal.Warp(out_path+"tmp.tif", src_ds, options=options)
*Command line work ok:*
     gdalwarp -s_srs EPSG:4326 -t_srs EPSG:32628 -overwrite -tr 20 20
-wm 9000 -multi -r near -te 453123 1702425 454123 1703425 -te_srs
EPSG:32628 /cygdrive/i/indata/VPDsc/VPD_scalar.tif
/cygdrive/i/data/SNDHR/VPDsc/VPD_scalar_test.tif
Assuming using -te_srs and -t_srs are redundant?
("*outputBoundsSRS* – SRS in which output bounds are expressed, in the
case they are not expressed in dstSRS")
Regards
/Jonas
On 02/11/2022 12:03, Even Rouault wrote:
> Jonas,
> The doc is at:
> https://gdal.org/api/python/osgeo.gdal.html#osgeo.gdal.TranslateOptions
> Even
> Le 02/11/2022 à 11:53, Jonas Ardö via gdal-dev a écrit :
>> Dear gdal-gurus,
>> I am new to using gdal via Python.
>> As the command line arguments/keywords differ from command prompt
>> mode and Python-mode (for example for example is *-r* in
>> gdal_translate  the same  as *resampleAlg* in gdal.Translate in Python).
>> I find it tricky to find arguments/keywords in Python.
>> How can all options/full syntax for gdal-pythons commands be listed
>> as done here
>> <https://gis.stackexchange.com/questions/352643/gdal-translate-in-python-where-do-i-find-how-to-convert-the-command-line-argum>
>> Where they also refer tohttps://gdal.org/python/ which do not exist.
>> Any other (full/completed) online resource for this?
>> Can "pydoc -g osgeo" be used?
>> Are the The gdal-dev Archives searchable?
>> Regards
>> /Jonas, Lund University, Sweden
>> gdal-dev mailing list
>> gdal-dev at lists.osgeo.org
>> https://lists.osgeo.org/mailman/listinfo/gdal-dev
> http://www.spatialys.com
> My software is free, but my time generally not.
Jonas Ardö
Physical Geography and Ecosystem Science
Lund University
Sölvegatan 12 22362 Lund Sweden
+46462224031
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20221102/6e2a721a/attachment.htm>
