[gdal-dev] Specify Grid Rotation for gdal.Warp() with Geolocation Arrays
Brendan Heberlein bheberlein at wisc.edu
Fri Nov 4 16:50:42 PDT 2022
Hi Mike,
thanks for the response.
Can you clarify how I would go about specifying the grid orientation for the output raster? None of -te, -ts or -t_srs address this.
Sent: Friday, November 4, 2022 6:41 PM
To: Brendan Heberlein <bheberlein at wisc.edu>
Cc: gdal-dev <gdal-dev at lists.osgeo.org>
Subject: Re: [gdal-dev] Specify Grid Rotation for gdal.Warp() with Geolocation Arrays
that's exactly what the warper does with geolocation arrays, set the target extent, dimension, and crs with -te, -ts, -t_srs with gdalwarp.
python will have those analogous controls for the warper.
Cheers, Mike
On Sat, 5 Nov 2022, 01:23 Brendan Heberlein via gdal-dev, <gdal-dev at lists.osgeo.org<mailto:gdal-dev at lists.osgeo.org>> wrote:
Hello,
I would like to be able to warp an image dataset using a geolocation array, while specifying the grid to which the output dataset is sampled. Specifically, I want to be able to warp the dataset to a grid which is not oriented North-up.
Can GDAL support this currently? Or, what is the likelihood this could be supported in the future?
I primarily rely on the Python bindings, so a solution within that framework would be ideal for me.
Thanks!
     — Brendan
gdal-dev mailing list
https://lists.osgeo.org/mailman/listinfo/gdal-dev
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20221104/8136cf84/attachment.htm>
