[gdal-dev] Specify Grid Rotation for gdal.Warp() with Geolocation Arrays
Michael Sumner mdsumner at gmail.com
Fri Nov 4 16:41:35 PDT 2022
that's exactly what the warper does with geolocation arrays, set the target
extent, dimension, and crs with -te, -ts, -t_srs with gdalwarp.
python will have those analogous controls for the warper.
Cheers, Mike
On Sat, 5 Nov 2022, 01:23 Brendan Heberlein via gdal-dev, <
gdal-dev at lists.osgeo.org> wrote:
> Hello,
> I would like to be able to warp an image dataset using a geolocation
> array, while specifying the grid to which the output dataset is sampled.
> Specifically, I want to be able to warp the dataset to a grid which is not
> oriented North-up.
> Can GDAL support this currently? Or, what is the likelihood this could be
> supported in the future?
> I primarily rely on the Python bindings, so a solution within that
> framework would be ideal for me.
> Thanks!
>      — Brendan
> gdal-dev mailing list
> https://lists.osgeo.org/mailman/listinfo/gdal-dev
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20221105/cf5abb16/attachment.htm>
