[gdal-dev] Specify Grid Rotation for gdal.Warp() with Geolocation Arrays
Brendan Heberlein bheberlein at wisc.edu
Fri Nov 4 06:22:30 PDT 2022
Hello,
I would like to be able to warp an image dataset using a geolocation array, while specifying the grid to which the output dataset is sampled. Specifically, I want to be able to warp the dataset to a grid which is not oriented North-up.
Can GDAL support this currently? Or, what is the likelihood this could be supported in the future?
I primarily rely on the Python bindings, so a solution within that framework would be ideal for me.
Thanks!
     — Brendan
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20221104/299c9163/attachment.htm>
