[gdal-dev] [OSGeo/gdal] Add GDT_Int8 support (RFC 87) (PR #6633)
Even Rouault even.rouault at spatialys.com
Tue Nov 8 16:04:39 PST 2022
Sean,
> Changing GDT_Byte to unsigned char is too big of a change, I guess? I
> can work with that.
GDT_Byte semantic is already unsigned char / uint8. What did you mean?
> Is there any advantage to a GDT_UInt8 type that can't be changed by a
> PIXELTYPE option?
That would be super confusing if we had both GDT_Byte and GDT_UInt8 and
they are not just simple aliases.
The PIXELTYPE option should die. The RFC proposes to make it die on the
reading side (as a metadata item).
We could also make it die on the writing side as a creation option, but
I didn't dare to do it right now and just propose this is considered a
legacy deprecated way. Would certainly be something worth doing for a
GDAL 4.0 if such thing ever happened.
> On Tue, Nov 8, 2022 at 12:39 PM Even Rouault
> <notifications at github.com> wrote:
>         Ubyte (same as uint8) vs byte?
>     what do you suggest exactly: keep GDT_Byte in the enumeration and
>     add |#define GDT_UByte GDT_Byte| to create the alias ?
>>     Reply to this email directly, view it on GitHub
>     <https://github.com/OSGeo/gdal/pull/6633#issuecomment-1307736762>,
>     or unsubscribe
>     <https://github.com/notifications/unsubscribe-auth/AAAIHIKG7X65SX4OULJMUFTWHKT5TANCNFSM6AAAAAAR2E6MJY>.
>     You are receiving this because you commented.Message ID:
>     <OSGeo/gdal/pull/6633/c1307736762 at github.com>
> Sean Gillies
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/gdal-dev
http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20221109/599d3b8f/attachment.htm>
